Ягуар X-Type 2003год
Sergey14
Сообщение23.06.2009 11:02    Ягуар X-Type 2003год [цитировать]
Здрасте всем. Установка сиги на енто авто( руль справа ) потребует каких-нибудь глобальных трудностей ? Спасиб.
fwheel
Сообщение23.06.2009 20:04     [цитировать]
Может, поможет (сами не делали, но информация имеется)
Here is the 2002-2003 X-Type 3.0S
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red |+ |ignition harness |
| STARTER|yellow |+ |ignition harness |
| IGNITION|green/orange |+ |ignition harness |
| SECOND IGNITION|black (key sense) |+ |ignition harness |
| ACCESSORY|green/white |+ |ignition harness |
| POWER LOCK|green *1 |- |gry plug, pin 16 @ GECM *2 |
| POWER UNLOCK|blue *1 |- |gry plug, pin 14 @ GECM *2 |
| LOCK MOTOR|yellow/black | |grn plug, pin 3 @ GECM *2 |
| UNLOCK MOTOR|white/green | |brn plug, pin 5 @ GECM *2 |
| DISARM DEFEAT|white/black | |brn plug, pin 1 @ GECM *2 |
| PARKING LIGHTS +|red | |pin 5 @ headlight switch |
| PARKING LIGHTS -| | | |
| HEADLIGHTS|green/black |- |pin 13 @ headlight switch |
| DOOR TRIGGER|black/pink |- |gry plug, pin 3 @ GECM *2 |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|brown |- |gry plug, pin 22 @ GECM *2 |
| HOOD PIN|black |- |blu plug, pin 21 @ GECM *2 |
|TRNK/HTCH RELEASE|blue |- |brn plug, pin 16 @ GECM *2 |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK| | | |
| TACHOMETER|green/stripe | |any ignition coil |
| SPEED SENSE|blue |8 |grn plug, pin 20 @ GECM *2 |
| BRAKE WIRE|green/white |+ |brake pedal switch |
| HORN TRIGGER|black |- |brn plug, pin 14 @ GECM *2 |
| WIPERS|wht/grn(L),wht/blk(H|+ |steering column |
| LF WINDOW UP/DN|*3 | | |
| RF WINDOW UP/DN| | | |
| LR WINDOW UP/DN| | | |
| RR WINDOW UP/DN| | | |
| SUN RF OPN/CLOSE|*3 | | |
| SUN ROOF LIMIT| | | |
| RADIO 12V|brown/white |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/green |+ |radio |
| RADIO ILLUMINATE|orange (dimmer) |+ |radio |
| POWER ANTENNA| | | |
| LF SPEAKER|white - yellow | |radio |
| RF SPEAKER|wht/red - yel/red | |radio |
| LR SPEAKER|wht/blu - yel/blu | |radio |
| RR SPEAKER|wht/grn - yel/red | |radio |
Notes:
NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555U to bypass. *1 These wires will meter while turning the key in the driver door key cylinder. *2 The GECM (General Electronic Control Module) is behind the glove box near the kick panel. *3 Interface of aftermarket window module is not possible because the motors are integrated with the control modules. However, an extended trigger on the door lock wire will roll the windows up and close the sunroof.
fwheel
Сообщение23.06.2009 20:08     [цитировать]
А, да.... Это для американца! Могут быть отличия!
