MB W211 2002г дизель АКПП
Сообщение25.11.2008 09:59    MB W211 2002г дизель АКПП [цитировать]
Ребят, есть у кого наработки? Приедет на след. неделе.
Надо сигу без запуска.
kola
Сообщение27.11.2008 19:58     [цитировать]
CAR ALARM SUPPLY
Positive: connect to the shunt in the fuse box.
Negative: Connect to the manufacturer’s original setting.
IMMOBILIZER
Starter Motor: cu the Purple (pos.n°2)wire in the Black 6-pin connector located in the bonnet driver side.
Fuel Pump: cut the Red/Green (pos.n°3)wire in the Black 7-pin connector in the central place in the boot driver side.
ODOMETER
Connect to the Grey/White (pos.n°14)wire in the Black 48-pin connector in the central place in the box in the bonnet driver
side.
POSITIVE IGNITION KEY (+15)
Connect to the positive ignition key. Attention that is present in time of starter.
CENTRAL DOOR LOCKING (Connection with RF remote controlled alarm)
Is impossible to control the central door locking in how much the system works through net CAN.
ARMING OF PASSIVE TYPE ALARM (Connection with alarm armed by vehicle’s original remote control)
Follow the method connections in the INSTALLATION FILE 25.54.1
DIRECTION INDICATORS
Front indicators: connect to the Grey/Black (front left) in the White 10-pin located in the rear part in the fuse box in the
bonnet driver side and the Black/Green (front right) in the White 6-pin connector in the space behind footstool passenger
side.
Rear indicators: connect to the Black/Green (pos.n°3) and Black/White (pos.n°11) in the Black 14-pin on the central
N.B.: in the connection of direction indicators don’t expect the ignition of direction indicators.
ONLY FOR TOP CAN/MULTICAN ALARM.
After completing connections, set the product for direct blinker control (select “A” for function 18 in the
operating functions, refer to the table in the installers manual).
DOOR PROTECTION
Connect to the Brown/Yellow (pos.n°9) (front left), Brown/White (pos.n°6) (front right), Brown/Blue (pos.n°11) (rear
left) Brown/Purple (pos.n°10) (rear right) in the Black 12-pin connector place in the boot driver side.
Separate the lines with the diodes.
MERCEDES CLASSE E MOD[1].2002.pdf
 Имя файла:  MERCEDES CLASSE E MOD[1].2002.pdf
 Размер файла:  53.35 KB
 Скачано:  1000 раз(а)
Сообщение28.11.2008 01:04     [цитировать]
смотри личку
Sergunja
Сообщение28.11.2008 02:17     [цитировать]
А с пацанами в Клубе перетереть?
Сообщение28.11.2008 23:49     [цитировать]
Sergunja
Без вопросов , но если Денис спросил здесь , тут и отвечаю Улыбаюсь , но в личку , чтобы не сбивать с волны других
Сообщение01.12.2008 10:34     [цитировать]
В пятницу в эту буду делать, как чего отпишу....позвоню..... Упс
kirlito
Сообщение15.02.2013 09:49     [цитировать]
Други, подскажите точки на данный авто (w211), интересует цвет, месторасположение, полярность... Сига без кана, нужна, только для управления Ц.З., шоб моргали повороты, ну и концевики 4 дверей. Заранее спасибо.
