Ситроен С2 запуск :(
Сообщение13.11.2008 15:16    Ситроен С2 запуск :( [цитировать]
Ребят, просят запуск на этого француза, а мне чегот не сильно хоцца...наработок нет вообще Расстроен
Может есть у кого нить инфа по нему
авто 2004г МКПП
kola
Сообщение13.11.2008 21:48     [цитировать]
Что есть.SPECIFIC VEHICLE ALARM FITTING INSTRUCTIONS REV. 00
www.cobra.it
PETROL
MAKE CITROEN MOD. C 2 YEAR 04 fi
®® DIESEL
x
ALARM/SIREN
POSITION
Position the compact alarms and the sirens on the wheelhouse driver’s side, near
the brake fluid cup, in the engine compartment.
CENTRAL UNIT POSITION Position the modular systems and the modules under the dashboard, driver’s
side.
POWER SUPPLY +30: connect to the 3 mm2 YELLOW wireat the position nr.2, of the 2 way
grey/yellow connector, coming out of the front part of the BSI operating central.
- 31: connect to the wire coming out of the ground terminal located behind the
left lateral bulkhead, driver’s side.
IGNITION WIRE +15/54: connect to the BLACK/YELLOW wire, located in the 2 way black
connector, in the BSI central, in the fuse box under the driver’s side dashboard.
DIRECTION INDICATORS Connect to the GREEN wire at the positions nr.13 and to the WHITE wire at the
position nr.14, on the coming out of the 16 way black connector, in the fuse box.
ELECTRIC WINDOWS Positive control signal
Temporized signal
Refer to the fitting diagram nr. 219.
CENTRAL DOORS LOCKING Original door motor control signal
Cut the wires: WHITE, at the position nr. 13 (lock) and BROWN, at the position nr. 15
(unlock) located in the wiring harness coming out of the 16 way grey connector. Refer to
the “A” section of the diagram nr. 221 for Bridge serie antithefts and to the “B” section
of the fitting diagram nr. 221 for 3100, 3900 series antithefts and Cobra Connex .
IMMOBILISATION POINT Fuel pump
Cut the VIOLET wire, at the position nr.9, in the 16 way black connector, behind
the left lateral bulkhead, driver’s side.
STARTER +50: Cut the YELLOW wire located in the wiring harness coming out of the 3 way
connector, on the left of the steering column.
BONNET SWITCH Install an additional switch on the front headlamp support plate, driver’s side.
DOORS SWITCH Connect to the LIGHT BLUE wire, at the position nr. 32, of the green connector,
inside the connection with white covering, in the fuse box.
Note: the polarity of the lamp is positive. Invert the signal with a micro-relay.
BOOT SWITCH Connect to the BLACK wire, at the position nr.16, in the grey connection of the
40 way connector, in the fuse box.
cic204gbb.doc
Note: This information is not binding, therefore it must be considered only an example for installation purposes that must be executed
as per the instructions given on the product installation manual.
www.cobra.it
FITTING DIAGRAM NR. 219
Diagram to make the windows locking with automatism on
CITROEN C2 year 2004
M M
+30
1 2 3 4 5 6 7
Art. 1055
Driver’s side Passenger’s side
window push button window push button
BROWN BROWN
BROWN
Diodes 1N5406
CPU CPU
windows windows
central central
cic204gbb.doc
www.cobra.it
FITTING DIAGRAM NR. 221
Diagram to make lock/unlock of the doors
on CITROEN C2 year 2004
M
+30
M
+30
A section
B section
VIOLET/ORANGE
VIOLET
YELLOW/BLACK
ORANGE
GREY/BLACK
WHITE
pos. nr.13
BROWN
pos. nr.15
VIOLET/WHITE
ORANGE/WHITE
VIOLET
YELLOW/BLACK
ORANGE
GREY/BLACK
WHITE
pos. nr.13
BROWN
pos. nr.15
cic204gbb.doc
Сообщение14.11.2008 17:19     [цитировать]
Всё открестился от него.......
