подскажите по DODGE NEON 2003
ALEKCEY
Сообщение10.02.2008 17:12    подскажите по DODGE NEON 2003 [цитировать]
Кто подскажет точки подключения сигнализации с автозапуском SL.
kola
Сообщение11.02.2008 00:51     [цитировать]
DODGE
MODEL YEAR(S)
NEON 2003 -
KEY T-HARNESS IMMOBILIZER
CHRY KEY-1 N/A CHRYSLER'S SENTRY ANTI-THEFT TRANSPONDER System (GRAY IGNITION KEY), Requires 791 Bypass Module and Extra Ignition Key
PART COLOR LOCATION
12 VOLT CONSTANT PINK/BLACK (+) IGNITION SWITCH HARNESS
STARTER YELLOW (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLUE (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 BLACK/ORANGE (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 BLACK/WHITE (+) IGNITION SWITCH HARNESS
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) BLACK/YELLOW (+) @ STEERING COULMN HARNESS
POWER LOCK LIGHT GREEN (1-Wire Door Lock System) See NOTE *1 IN DRIVERS KICK PANEL, See DIAGRAM
POWER UNLOCK Same wire, See DIAGRAM See DIAGRAMS
DOOR TRIGGER YELLOW (-) IN DRIVERS KICK PANEL
DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires #775 Relay
TRUNK RELEASE BROWN/LIGHT BLUE (-), Requires #775 Relay @ HATCH RELEASE SWITCH in GLOVE BOX
SLIDING POWER DOOR N/A
HORN BLACK/RED (-) @ STEERING COLUMN HARNESS
TACH BLACK/GRAY @ COIL PACK
WAIT TO START LIGHT N/A
BRAKE WHITE/TAN (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM DISARMS WITH UNLOCK
ANTI-THEFT CHRYSLER'S SENTRY KEY (GRAY KEY ONLY) A TRANSPONDER SYSTEM TRANSPONDER @ IGNITION SWITCH TUMBLER
EXTRA INFORMATION
NOTE *1 this vehicle uses a 1-Wire Door Locking system, if vehicle is WITHOUT a FACTORY ALARM SYSTEM, LOCK requires a (-)Negative thru a 1000 Ohm Resistor and UNLOCK is a (-)Negative thru a 250 Ohm Resistor. If vehicle HAS a FACTORY ALARM SYSTEM, ARM/LOCK is a (-)Negative thru a 2700 Ohm Resistor and DISARM/UNLOCK is a (-)Negative thru a 7500 Ohm Resistor, some units will require 2 extra relays part #775, to connect, See DIAGRAM.
ALEKCEY
Сообщение13.02.2008 22:39     [цитировать]
Огромное спасибо.
