RX400h
S.N.N.
Сообщение25.09.2007 00:49    RX400h [цитировать]
Кто-нибудь что-нибудь на него ставил?Поделитесь опытом.
kola
Сообщение25.09.2007 01:54     [цитировать]
12 VOLT CONSTANT RED (+) @ IGNITION HARNESS
STARTER BLUE (+) @ IGNITION HARNESS
STARTER 2 N/A
IGNITION 1 PURPLE (+) @ IGNITION HARNESS
IGNITION 2 GREEN (+) @ IGNITION HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 BROWN (+) @ IGNITION HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE BLACK (-) See NOTE *1 @ IGNITION HARNESS
PARKING LIGHTS ( - ) ORANGE (-) @ HEADLIGHT SWITCH
PARKING LIGHTS ( + ) LIGHT GREEN (+) IN DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE.
POWER LOCK BROWN (TYPE B) See NOTE *2 @ DRIVERS DOOR MODULE in DRIVERS DOOR
POWER UNLOCK GRAY (TYPE B) Requires Double Pulse @ DRIVERS DOOR MODULE in DRIVERS DOOR
LOCK MOTOR WIRE BLUE to RED (+) IN DRIVERS KICK PANEL, 20-Pin Plug, Pin 1
DOOR TRIGGER See NOTE *3 26500_RX-400H_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
DOMELIGHT SUPERVISION LIGHT BLUE (-) @ RIGHT SIDE of FUXEBOX, 12-Pin Plug, Pin 5
TRUNK RELEASE PURPLE (-) @ POWER BACK DOOR SWITCH on DASH
SLIDING POWER DOOR N/A
HORN WHITE (-) @ HORN SWITCH
TACH ANY wire NOT RED, WHITE/RED or WHITE/BLACK @ ANY IGNITION COIL or FUEL-INJECTOR
WAIT TO START LIGHT N/A
BRAKE BLUE (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM DISARMS with UNLOCK
ANTI-THEFT LEXUS TRANSPONDER ANTI-THEFT SYSTEM @ IGNITION TUMBLER
NOTES
NOTE *1 The KEYSENCE BLACK (-) wire can be used as a DISARM wire for the Factory Security, a constant (-) Negative to this wire will DISARM.
NOTE *2 TEST the LOCK and UNLOCK wires while turning the Key in the DRIVERS DOOR KEY CYLINDER.
NOTE *3 The DRIVERS DOOR is a BLUE (-) at the BECU, 16-Pin Plug, Pin 14. The PASSENGER DOOR is a BLUE (-) at the BECU 28-Pin Plug, Pin 23. The DRIVERS REAR DOOR is a GRAY (-) at the BECU, 16-Pin Plug, Pin 16. And the PASSENGER REAR DOOR is BLACK (-) Pin 7, in a 13-Pin Plug on the RIGHT SIDE of the FUSE BOX. When connecting to an ALARM SYSTEM use all 4 wires and DIODE ISOLATE, See DIAGRAM.
Sergunja
Сообщение26.09.2007 00:41     [цитировать]
Знаю я этот сайт Улыбаюсь осторожно там много неточностей!
kola
Сообщение26.09.2007 01:45     [цитировать]
Верь себе, закону Ома и мультиметру.
Sergunja
Сообщение26.09.2007 11:46     [цитировать]
Хорошо сказано! Очень счастлив
S.N.N.
Сообщение26.09.2007 22:40     [цитировать]
Поделитесь опытом.
