Cadillac Srs(srx) 2007
stiwi
Сообщение16.01.2014 23:34    Cadillac Srs(srx) 2007 [цитировать]
не разу не делал кадилаки . Кто ни будь может поделиться точками ?
Сообщение18.01.2014 16:15     [цитировать]
Вот что есть:
2007 Cadillac SRX Last Update:  11/13/2008
Circuit Wire Color Location
  Constant 12 volts RED/WHITE AT BCM * BLACK CONNECTOR PIN 1,2
  Ignition 12 volts PINK AT BCM * GREEN CONNECTOR PIN 14
  Starter WHITE/BLACK *** AT BCM * GREEN CONNECTOR PIN 2**
  Dome Light GRAY/BLACK (+) AT BCM * PIN C6 SEE TECH
  Trunk Pin ORANGE/GRAY (-) AT BCM * PINK CONNECTOR PIN 12
  Parking Lamp BROWN/WHITE (-) AT BCM WHITE CONNECTOR PIN 8
  Lock GRAY DR AND PASS L GRN IN EACH DOOR ** #205
  Unlock TAN DR AND PASS GY/BLK DUE TO MULTIPLEXING **
205 - See Reversal Rest at Nothing Door Lock Diagram * The BCM (BODY CONTROL MODULE) Is Located Behind The Glove Compartment On The Right Hand Side. ** Check For Door Lock Modules
  Tach Signal L BLUE/BLACK PIN 28 BLACK 73 PIN CONN AT (PCM) MODULE *
  Ignition #2 NONE #239
  Ignition #3 NONE #241
  Accessory BROWN AT BCM * GREEN CONN PIN 14
  Neutral Safety GRAY/ORANGE AT TRANSMISSION SLECT SWITCH
  Brake Light YELLOW (+) AT BCM BROWN CONN PIN 1
  Reverse Light WHITE (+) AT BCM PINK CONN PIN 2
  Rear Defrost WHITE (+) H VAC CONTROL MODULE **
#239 - See Immobilizer Bypass Circuit Diagram
#241- GM Passlock 2004 Interface Diagram *Powertrain Control Module (PCM) Is Located Front Left Side Of The Engine Compartment, Inside The Air Cleaner Housing ** The VAC Is Located In Front Of The Passenger Compartment,On The Front Center Of The Instrument Panel.
stiwi
Сообщение18.01.2014 21:03     [цитировать]
вова спасиб
