Нужно для установки сигнализации.
мишка
Сообщение26.12.2009 21:37    Нужно для установки сигнализации. [цитировать]
Нужно для установки сигнализации заводские цвета и расположение проводов по автомобилю Ford Explorer 2004 г.
Сам могу предложить для:
ФОРД ФЬЮЖН
ФОРД ФОКУС II
ФОРД S-MAX, Galaxy, Mondeo
FORD EXPEDITION
Есть еще.
Сообщение26.12.2009 23:38     [цитировать]
12 VOLTS yellow + ignition harness
STARTER 1 red/lt. blue + ignition harness
STARTER 2 n/a
IGNITION 1 lt. green/purple + ignition harness
IGNITION 2 n/a
IGNITION 3 n/a
ACCESSORY 1 brown (x2) + ignition harness
ACCESSORY 2 black/green + ignition harness
POWER LOCK pink/yellow driver kick panel On models with keyless entry the door locks are negative trigger. Without keyless entry they are 5wi reverse polarity.
POWER UNLOCK pink/lt. green driver kick panel On models with keyless entry the door locks are negative trigger. Without keyless entry they are 5wi reverse polarity.
DISARM NO UNLOCK see factory alarm disarm
FACTORY ALARM ARM arms on lock Arms on lock only with door open. It is necessary to send a signal to door trigger as well as lock to arm factory alarm.
FACTORY ALARM DISARM dk. green/purple - driver kick panel
DOORLOCK MOTOR pink/black 5wi driver kick panel
DOOR UNLOCK MOTOR red/orange 5wi driver kick panel
PARKLIGHTS POSITIVE white/black or brown + headlight switch or dkp
PARKLIGHTS NEGATIVE white/purple - csm behind glove box
REVERSE black/pink + driver kick panel
BRAKE lt. green + brake pedal switch
DOOR PIN yellow/black (l), gray/red (r) - each door harness Use both wires and diode isolate each from the GEM module, refer to DirectFax document 1076 for wiring information.
HOOD PIN tan/lt. green - driver kick panel
TRUNK PIN white/purple - driver kick panel
DOMELIGHT SUPERVISION use door trigger
TACH tan/yellow ac pcm The PCM (Powertrain Control Module) is located at the top of the firewall towards the passenger side. The tan/yellow tach wire is also found at the back of the instrument cluster. Can also use any tan/stripe wire at the coil pack.
У меня есть только это.
Серёга К
Сообщение27.12.2009 18:10     [цитировать]
Ставил на Ford Explorer 2005 года
Зам заж
Жёлтый +12в
Краснозелёный зажигание
Красный старт
Тёмнозелёный АСС
Двери в водит углу, в жгуте который тоньше, провод цвета даже не знаю как его правильно назвать типа
Тёмносинепурпурного с чёрной полосой там по минусу без задержки.
Габариты в томже жгуту коричневый провод
Центрозмки, в водит углу в жгуту который толще
Тонкие провода (по минусу)
Розовожёлтый- закрыть
Розовозелёный- открыть
Повороты в жгуте идущем на руль
Белосиний правый
Зелёнобелый левый
Контроль
По генератору
Возле гены зелёнокрасный провод
УДАЧИ
Серёга К
Сообщение27.12.2009 18:14     [цитировать]
А забыл ещё, блок сигналки сложно куда либо засунуть(помучился).
мишка
Сообщение27.12.2009 18:59     [цитировать]
Спасибо за помощ.
По конценвикам дверей
Не совсем понял, двери по + , разводить каждую через диод- задержка очень большая. А у тебя я так понял к плафону.
P.S Explorer 3-ий и 4-ий в 2005году выпускались, мне нужно по третьему.
